sxtheviper
Hello!
I got a clutch set up from Turk, and I just wonder if any of you have tested it? Then i mean on a sxr 500, vmax 500 or something like.
8ab yamaha weights and 47/41 helix. And 2.4 grams in each hole of the weights.
Thanks!
Thanks!
that vmax jhons set up from the tec pages. accoding to everone here that has tried it on their 500 it is the setup to run.
its goin on my 500 with a minor mod to the primary weights as soon as i get my parts from maximum perf. i wanted weights that where easyer to adjust so i went with aftermarket 40 gram base weights that the holes are threaded so it is easyer to fine tune for me.
im shure someone else will chime in or you can do a search for clutch setups for sxr 500 vmax 500 venture 500 xtc 500 etc. lots of guys here runnin that set-up.
