n2oiroc
Its for your track drive shaft.... maybe to hold on a reluctor wheel for your speedometer????? Some have a cable (srx) and some have a trigger wheel for a pickup to measure track speed!!! Do I win a prize??????? Gary Oles nosboy
n2oiroc
that might be it. thats about the only think i havent put back on yet. i wonder why it has a hole through it. oh well, thanks!
richierich
it is the drive shaft bolt that holds the speedo pickup sensor on.normally i would say leave it off just added weight but you might want to know how fast you are going
n2oiroc
or when i sell it in a few years i can be commended on how low the mileage is on it! lol!richierich said:it is the drive shaft bolt that holds the speedo pickup sensor on.normally i would say leave it off just added weight but you might want to know how fast you are going
maxdlx
VIP Lifetime Member
I need to fix my speedo gear on my viper. Man you can go fast when you switch to 8 tooth drivers. I just can't remember to take 1 or 2 teeth off. Maxdlx
n2oiroc
1 tooth for 9's, 2 teeth for 8's. i have 8's with 2 teeth removed and it seems real close to accurate.maxdlx said:I need to fix my speedo gear on my viper. Man you can go fast when you switch to 8 tooth drivers. I just can't remember to take 1 or 2 teeth off. Maxdlx
maxdlx
VIP Lifetime Member
Did you just use a hand grinder or what. thanks Paul
n2oiroc
a dremel with a fiber cut off wheel. then i finished it with a 1/4" sanding drum. 2 teeth opposite sides.maxdlx said:Did you just use a hand grinder or what. thanks Paul
Harry Balzonya
- Nov 12, 2004
- corner brook,nf canada
- www.poppaduff.piczo.com
one of the front suspension bolts?
maxdlx
VIP Lifetime Member
it is the speedo bolt, i don't know what the hole is for, but it is for sure the speedo bolt
tomseal6
looks like the secondary clutch bolt to me
n2oiroc
it was the speedo gear bolt. its back in now. thanks for all the help guys!
98srx6
Is the hole cut through the entire length of the bolt? Why?
maxdlx
VIP Lifetime Member
I have a theroy on it. It calls for locktite on the threads, and it goes in the drive shaft end, where there is no way for air to escape. If you didn't have a hole in the bolt it would act like hyralics, and cause problems. What ya think Maxdlx
