Tors what's that
bansheedan
Ontario
I put all my sled back in one peice
Start it and it runs fine
:die:
press on the gas and the (tors light) comes on and it run like shit it wants to stall or if i press harder on the gas it rev to the max
what could that be please help me i want to go riding
float are at 22mm
air screaw at 1 1/2
down by the carb rack there are 2 wires that hook to the carbs. Unplug them, and plug the 2 ends that go to the handlebars back into each other, and give it a try. I'd also try loosening your throttle cable up first. Maxdlx
Ok now i unplug the tors
I cleaned the carbs to the max
air screaw at 1/2
but even after that when i give it gaz it fells like stalling
but after playing with the gas a little bit like 4 secondes it start's going not fast but one it's start it goes good
what could that be thanks
Loosen your throttle cable so that there is a very small amount of free play. Plug tors back in and give it a try again.
maxdlx said:
I hope your fuel screws are at 1 1/2, not 1/2. Maxdlx
yep that's why I meant sorry
problem with the tors is ok now i think
now i just got to find a way to fix the low end bog
Check if the bog still exists with the choke flipped on. If it does, you need to give it more fuel by opening the fuel screw a bit more.
There no more ajustement for the throttle cable, it not reving high enouff the rpm is to low like 1000 what should i do to make the rpm go higher
there is a seperate adjustment for the idel. The idel is the big shinny screw head down by the carbs, it has a knurled edge to be able to turn it with your fingers. The throttle cable adjustment is donr where the throttle hooks to the carb. I always make my throttle to where you can see it move the cable skightly befor the slides move any. This probablly will confuse you more, but I'm not good at putting the pictures in my mind into words. Maxdlx
All of my Yamahas have liked to have the throttle just slightly cracked open to start when warm. Just crack the throttle open slightly with right hand and pull with left, first pull everytime when warm, otherwise it takes forever.
