1 Trick Viper
What are the pros and cons of adding a reverse kit to a Viper? Besides some extra weight, are there gearing limitations?
if you want to really gear down for the 136" you can just run 8 tooth drivers with stock gearing.1 Trick Viper said:I am currently using a 22/40 gear combination. Can I still use this gear ratio with a reverse kit? I want to have several choices available since I just finished putting in a 136" conversion. I am not sure if I will need to gear down more because of the extra track. Any thoughts?
i really like the kit too, except the cheap rivets. stock er gearing is 22/38.1 Trick Viper said:Anybody know the stock gear ratio for a Viper ER? I think that would be a good starting point and then I can compare that to the 22/40 with the 121" track that I did have.
n20iroc - I have been following your modifications and I did something similar but I used a MaxxPerf 136" kit with the longer rails and a 1" track. That MaxxPerf kit is a pretty nice kit.
