Straight 47 Helix, spring wrap initially at 70, then I twisted up to 90, seemed to help a little. On cool clutches, it was not as bad as when they heated up. EGT temps same, clutch heat got hotter. At the beginning of the day, I had only small rivot in shoulder. I took it out and put the large rivot in. It pulled harder and really felt better. FYI, it is over revving a little bit still right now. That's what leads me to believe its in the secondary. From a roll on, it pulls smooth and hard all the way through so the engine is pulling it. Just from a dead standstill I am getting a helacious bog about 100-150 feet out. About when it starts really hooking. As far as what is in the tip and middle holes, not sure. I bought this sled from a buddy (SRXRacer on here) and am just tweaking it to fit my needs. I used his set up as a baseline so I have no Idea what is in there. I was planning to add and subtract as needed. Does this give you enough to go on?
Part of the problem is that it's not coming out real smooth. It's leaving so hard that it is bobbing a little bit and when it finally settles back and stops the bouncing is when it bogs. I am tuning the bounce out which will help the bog, but again, does this sound like primary or secondary to you? Remember, low speed roll ons show a very good shift curve as it slams to 9100 and creaps to 9400-9500. Your thoughts?
