F Freerider New member Joined May 2, 2003 Messages 19 Location Sweden Feb 18, 2004 #1 What is the correct procedure for tensioning the chain on an older (94-96) V-max? I am fixing my buddys -96, and noticed the tensioner is spring loaded. Any input appreciated!!
SledderSteve VIP Member Joined May 9, 2003 Messages 208 Age 66 Location Mukwonago, WI Feb 18, 2004 #2 It's too simple 1. Loosen the locknut on the adjuster bolt. 2. Turn the adjuster bolt clockwise until it's finger tight. 3. Hold the adjuster bolt in place then tighten the locknut.
F Freerider New member Joined May 2, 2003 Messages 19 Location Sweden Feb 18, 2004 #3 Ok thanks, same procedure as on a non-spring preloaded one then? What is the purpose of the spring anyways?
SledderSteve VIP Member Joined May 9, 2003 Messages 208 Age 66 Location Mukwonago, WI Feb 18, 2004 #4 The spring tensioner's job is to cushion the slack action in the chain to help prevent breakage. Chain breakage is most often caused by a sharp, sudden load. The spring tensioner works to even out the load and make it more constant.
