..SNAKEBIT..
WHAT should I buy?? size strength? how long?
dont want to buy a piece of crap.
I would like to buy before I tear apart to replace
is there a fix for the rubbing on the chaincase bracket?
yamaholic22
I just bought one last week at the dealer, that is very good rope.
richierich
i have a brand new oem viper one that i never used.i can send it with your other stuff.
..SNAKEBIT..
YOU DA MAN RICH!
save me from going and looking, but I dont want to bend over! LOL
richierich
$4 your cost.retail is $7.77.is that ok?
98srx6
snakebit, there is some kind of plastic insert that you can get to eliminate the rubbing on the chaincase. Your dealer should be able to get you one cheap.
richierich
oh ya.the insert is $1.92 retail.i dont have one here though.
part#8FF-1546C-00-00
bucky
I found a little bur where mine was rubbing. I jsut filed it down smooth. so far so good!
SXViper 1+2=3 cylinders
- Feb 27, 2005
i've already had to replace mine twice. they don't last very long, even with the update done. gonna have to do some poling around where it's rubbin i guess.
look
Sure thing fix for the pull rope problem. ELECTRIC START. LOL Made you look. Maxdlx
..SNAKEBIT..
my mom told me if I cant pull start it I cant ride it.
yamaholic22
..SNAKEBIT.. said:my mom told me if I cant pull start it I cant ride it.
LOL, my uncle told me that same thing when i was like 10 with his ZRT 800, i got it started
yamvip
they had a recall,on that,i got a new rope and a plastic grommit insert!!Call your dealer they might replace for free.
..SNAKEBIT..
Rich
send the rope with my shipment, let me know when its mailed
bolin22
went through 4 starter ropes in 7 thousand miles.....3 plastic inserts in about 2 weeks....just took a round file and went to town on the case till it quite frayin the rope....a year later and the same rope, id say its fixed.....
Every fall cut the knot take another inch and re-tie, should be good for several years before rope length becomes an issue. That's what I've done several times when I notice some fraying at a rub point.
THKSNOW
this WAS/IS a dealer RECALL. Call your dealer, they should/will replace the rope and put in the plastic dealy FOR FREE--
Mac
Aircraft cable fixed forever
If you are looking for a permanent fix use aircraft cable. I've used steel cable for years in old Honda trikes and other worn out junkers with torn recoil cases. You can pull right through the sheet metal case forget replacing the button. Works perfect and I guarantee you won't break the cable. Remember to make the cable long enough not to bottom out the cable and break other parts.
My rope snapped tonight. I've got the recoil setup, but can't figure out how to route the rope to the handle! It shouldn't be this difficult. Anyone have a picture or able to describe where it goes? It obviously has to rub somewhere.
