Harry Balzonya
- Nov 12, 2004
- corner brook,nf canada
- www.poppaduff.piczo.com
what would be the best mod for a 03 viper
i know have no warrenty
98srx6
Pipes, new track, new skid, really depends on how much you want to spend.
Harry Balzonya
- Nov 12, 2004
1000-1500
n2oiroc
rear suspension and track.
B2SO
- Aug 18, 2003
the go fast parts are worthless without the traction, if you want a better ride , stretch it to 136 and a new track and maybe new shocks(rear) or a custom re-valve , and some clutching .just my opion
jimmie d
M10.
Jim
Jim
auji700triple
pipes for Power... makes the sled really open up!
Clutch it, tourque stop, and change out the track RipSaw min, if possible 136 it. other than that leave it alone
Cuzino19
136" M10 with a hacksaw and 108 studs.
quebec#1
What clutch kit would you go with (heel clickers?)kirkswim said:Clutch it, tourque stop, and change out the track RipSaw min, if possible 136 it. other than that leave it alone
Zion Lion
- Sep 18, 2005
I think you should buy my mbrp trail can, all you need for mods!
**sarcasm**
**sarcasm**
Harry Balzonya
- Nov 12, 2004
i would but i already gots a mbrp trail can
awsome sound
awsome sound
Maim
Super Moderator
quebec#1 said:What clutch kit would you go with (heel clickers?)
here is a link to his set up. it works awsome. im his brother and i rode his sled before and after. the clutching really woke it up.
www.**********.com/forums/showthread.php?t=13920&highlight=kirkswim
where the ********** is put yamaha info (no space)
03viperguy
gas oil and a ripsaw revalve the shocks with someone like pioneer performance, they made a nice big difference for me
vipertripplexxx
SRX pipes, SRX CDI and clutching.....................For lake racing
9818 track, clutching and shock revalve............For trail riding
All depends on what you want to do?
yamyrider
I would go for clutching a new track and some suspension work.
tomseal6
slp pipes, clutch kit, srx heads, rear heat exchanger, and a 121 rip saw are the best mods for a viper most of this you can get used on here and even spend less than $1500
Clutched mine with the 40-10 heelclickers, 3g heel 4 g tip if i remeber correctly with the red sping from kit. Secondary an Advant Edge 48-40 helix at 70 degree twist. It is sweet in the trails and will beat my freinds rev800 in a full out lake run(inches past him). For the money it was my best mod yet. Other than that stay away from the MBRP can sounds soooo sweeeet but loses hp. Clutched i run 8500rpm with stock can from -5C to -45C all the time. With the MBRB can if it is below -15C after some WOT runs it won't rev past 8100.
The rear cooler is also a very good idea.
Suspension wise i find it great in stock form but i do ride it rough and i am used to a rougher ride.(Rode mid to early 80's sleds till I bought it)
With above setup and stock track and jetting i hit 103mph(GPS) on a rough(frozen slush lake) at -45C.
If it ain't Broke "RIDE IT TILL IT IS!!!!"
NITROUS!!! What did you expect????? gary Oles nosboy
Mtnviper
The best answer, is another question. What kind of riding do you do? Trail, off trail, mountain, lake racing? What would you like it to do, be faster, ride smoother, handle better?
