136" Viper Project - Finished - Time to Ride!
couple of questions
n2oiroc said:
handling will still be very close to stock if you get better skis. if you run the stockers, it will push. i have the 05 mountain skis and really like them. they bite good and steering effort is really light for a deep keel ski. plus being a little over 7" wide with an adjustable stance (-1", stock and +1") makes them great on and off trail. here is mine with a maxx tunnel extension and tracks usa rail extensions.
1. What track are you running?
2. Did you have to do any relocating of the skid?
3. Any clearance issues? I seen a couple of post on trimming protectors?
4. Does the stock externsion covers work? I want to use a blue set.
5. Any way to trim off the aluminum that hangs down below the covers? I've only seen pictures of the extension, and not sure if I'd like it like that. Might not matter, though.
Thanks for the info so far
1. im running a 136" x 1.75".
2. i dropped the skid in the chassis. i didnt have to, but i did for clearance off trail.
3. no clearance issues at all.
4. with the maxx perf kit (the one i have) it can use the stock mm hose covers.
5. you could trim excess off if you dont use a stock rear cooler (again, maxx is the only one that lets you use a stock cooler, but it is optional!)
