ReaperSRX
I have just finished removing my shocks for revalve & long travel, and now want to remove stock rods, i have ordered Max rods, i have only removed the four back skid bolts and the skid is down, my question is how to remove the stock rods from there, not sure on how to remove wheel to access rod......help.......
AtlasFBG2
Place a block of wood over the shaft and wack it a few times with a hammer to break it loose.Just dont hit the shaft directly with the hammer or you will mess it up.Pull the wheel off and the rod then pull the shaft out from the opposite side of skid.
ReaperSRX
Thanks Atlas
Thanks for the info, might get a chance to try it tomorrow, will let you know how things went......James
also can thread a old 14 mm bolt in the end and pound on that.
trekkr
- May 2, 2003
Don't start pounding until you remove the c-clip from behind the wheel. I know, I know, that's a no brainer. But I've seen guys try.
SRXSRULE
- May 2, 2003
Trekkr....What are you talking about? If he takes that c-clip out he is going to remove the wheel and leave the bearing on the shaft. Maybe you were thinking of something else but to remove the transfer rods, all you do is drop the skid, try and support the wheel and pound on the axle using a block of wood or old bolt in the shaft to protect it when hitting it. One wheel will come off and then you slide the shaft out. ===SRXSRULE===
trekkr
- May 2, 2003
RULES - Yeah, holy cow, don't know what I was thinking. Thanks for the correction. I guess I was thinking there was a clip keeping the bearing on or something. My apologies.
trekkr, i think it's called a brain fart!!!!!!!!!!!!!!!!!!!
