Hi
I was riding today at -2 c, my sled is jetted for -7 and at wot, the dcs still came on, WHY? The carbs were just cleaned at my dealer. How am I supposed to shut up the dcs system?
adam4by4
Might Be Bad Or Low Octane Gas
I filled up with fresh premium.. But not a bad idea. Thanks for the reply.
03viperguy
dont bypass the dcs, its there for a good reason
Thunder Valley
OK... I'm humbled here and feel like a retard. What's the DCS, and what's it do?
auji700triple
DCS = Detonation... Detonation Means The Piston Firing Before it Hits Top dead Center(TDC) And is NOT good!! lol
x2ryder
The dcs is too touchy. Mine kept going off with my bigbore and the plugs and piston was looked fine. I bypassed mine and have put on lots of miles and no problems. I know when mine was stock I could not run near as lean of jetting as my friends srx's and he had looged on thousands of miles with his jetting. I am not saying to disconnect it I just don't care for it. 1998-2001 seemed to be fine without it.
x2ryder, with your fat jetting, did it shut up?
x2ryder
shut up?
x2ryder
I ran 148.8 147.5 147.5 and it seemed to be fine 93 octane gas.
x2ryder
on my bigbore I had 152 155 155 and everytime I hit the gas it would go off. disconnected it and now it runs fine
I meant did you run it stock with fat jetting? I may have found something here, seems like the needle position is only 2,5 instead of 3. One shim over and one under instead of both under. When is the needle in action (what rpm) and when are the mains in action? thanks.
x2ryder
I think the needle is up to 3/4 throttle mains wot
YAMMIEGOD3:16
NEED TO UP OCTANE DUDE. 3:16 (tony)
Already on premium. Could the needle position be the key?
when exactly does it go off?
ok, when is the light coming on only at wide open or when your cruising at about 60-70 down a packed trail??
You see the pilot, needles and mains all overlap each other, so a problem from idle to upper midrange would be addressed by the pilot, fuels screw, and needles. The main only contributes to total wide open fuel flow.
It sometimes is advantages to use a bigger pilot with fuel screw adjustment and play with the shims on the needle, instead of raising the clip on the needle as you can make 1/2 clip improvments or subtractions with the shims, they really help you fine tune the circuit in.
When I had my 02, I simply used 148.8/148.8/150-pto jetting, and had no issues with the dcs, this is the stock 2001 jetting, but you will have 42.5 pilots instead of 40 pilots and this helps to overlap(richen up slightly) the lower circuits.
the srx has a large fuel curve and you can be a couple jets sizes each way and the motor will produce the same hp, so its much better to be on the rich side a jet size or so, that way you dont need to worry about jetting for conditions.
Seems if I hold it open long enough at 8000 rpm and above and at WOT. The problem is mainly at wot. What elevation are you at? I'm almost at sea level. Which cyl is the bigger jet supposed to be at? My dealer put it on mag side, is that right??
Also, did you long lake pulls? thanks
That could be it! I have the 150 on the MAG side instead of the PTO side.
