C.R.E.A.M.
- Nov 20, 2005
1998 SRX 600. (got it for 1300$) Needs a new cylinder, piston, and set of rings. I bought another cylinder and head and valve, and am sending them off for tradein + spending some money, so I'll get 3 nice ported,polished cylinders with 3 modded heads and valves as well. Should be up and running by the new year!!!! 160ish HP SRX, here we come!
Never seen a trail ported 600 SRX get over 133 hp. Owned 2 of em.
kysledneck
I read his post & thought 160 HP Wow that seems high! But I have no experience with them!
Turk said:Never seen a trail ported 600 SRX get over 133 hp. Owned 2 of em.
03viperguy
congrats! PM me wioth details on what you did with everything else
update me
update me
C.R.E.A.M.
- Nov 20, 2005
The cylinders are from a 700 srx that are getting trail ported and put on.
Congrads
U must of been the highest bidder on EBAY on that 1............Well U finally got Your SRX U WANTED....
.........HAVE FUN.......& WELCOME TO THE FAMILY
....Just don't go 2 Nuts Right Away
C.R.E.A.M.
- Nov 20, 2005
thanks bountyhunter! Now i just gotta work! I want to get viper shocks for the front and back!!!
Your gonna need a 700 SRX CDI & different nozzles & jets in those carbs. You are probably better off to buy a used carb rack from a 700 SRX.The 600 carbs are the same size but the guts are entirely different.
C.R.E.A.M.
- Nov 20, 2005
why cant i use a 600 srx cdi? I heard they work better anyways.... ya im already trading for the 700 srx carb rack. Thanks turk. I'll probably need help clutching it when its all done
600 cdi has more advance=more chance of detonation with bad fuel or big problems if jetting is lean.
yamaholic22
yea you can use the 600 cdi but as turk said it has quite a few degrees more advance and will be more on the ragged edge when it comes to longer pulls and fuel quality. I wouldn't use the 600 box for anything more than 500 foot drags.
