03viper159
Anybody have a set of cpr pipes on there mountain viper, looking at getting a set, want to know about jetting and oil pump adjustment. For about 7500 to 10000 feet
thanks
thanks
n2oiroc
slp's seem to be a better choice, espically in the mountains.
ak ryda
I whole heartedly second the SLP choice. Do a search on here and on snowest for SLP pipes and you will see that SLP pipes produce the most power, are the most reliable, easiest to tune, quietest, and have the best fit and finish.
Mtnviper
I'll 3rd the choice on SLP's. Nothing against the CPR's, however for high elevation's, there seem's to be the most tuning info avilable for SLP's.
mountain_mod_viper
I'll put my cpr's up against ANY viper with slp's here in S.E Idaho. I'd even put $100 on mine (only because it's got a ton of other mods). But really, my group has 2 04 vipers with slp's; 1 with speedwerx; 1 03 with aaens; 1 03 with slp's; 2 03's with cpr's; and 1 05 with cprs. The guys with the other brands sure wish they had the cprs. I wonder how many of the guys that really push the slp's over the other brands have ridden with anything other than slp's.
03viper159
what kind of elevation do u run with the cprs, do u have a good jetting setup?
Arctic Crap, Ski Dont, Polarass
Arctic Crap, Ski Dont, Polarassvipertripplexxx
Voting for the SRX pipes, I had CPR's and the mileage was terrible. These pipes are just as strong as my CPR's, if not better.
Here is what you need....
SRX Pipes $150
SRX CDI $100
flanges $100, or make them yourself
Bender can $100
new springs $30
So for under $500 you can have that sweet mileage, and SRX power.
SRX Pipes $150
SRX CDI $100
Bender can $100
new springs $30
mountain_mod_viper
We ride 7-9000'. I've also got porting, different head, and 38mm carbs. I'm pretty sure that the other cpr's that I ride with are jetted pretty much the same as the slp website shows for the slp pipes. That should at least get you real close.
03viper159
how do those srx pipes fit under the hood of a viper?
vipertripplexxx
You have to carve out the right side belly pan to get them to fit,so you can see some of the pipe above the shock, but it does not hit the shock mount. If you use an aftermarket can the weight is not bad. you will need to reweld the position on two of the three pipes on the can it's not much, you just cut off the two pipes that don't line up, hold them where they should be and tack them into place. Then remove them and fully weld the pipes back. The hood slightly touches the pipes but with the shields it does nothing.
VIPER-D
what kind of jetting are you running.
VIPER-D
that q,s is for the srx pipes on a viper
skidooboy
i havent ran any other pipe on my viper but slps. i have raced a few with aaen, speedworks, bender, cpr. and yes i have a few mods on mine as well (all bolt on no internal work). my slps run consistantly well when the pipes are warm. fit, finish, sound, power, fuel economy. all there in my package. my vote..... SLP. not to say there arnt faster set ups out there, cause there is. remember when you think your the fastest, someone comes up and spanks ya. ski
vipertripplexxx
VIPER-D,
I'm running bored carbs 35.5mm, gutted airbox, bottom shelf gone, holes in top shelf. Carb vented to outside of box w/tempaflow, SRX 600 nozzels (Q2's), stock viper needles @ 4, 4, 4.5 on mag. 45 pilots, 1.0 pilot air jet, stock viper slide cutaway, 152.5 mains, airscrews around 2 turns. With tempaflow set at the zero point (-20f). That's darn close but could maybe use a 150 on the pto. use a SRX base gasket.
