Does anyone know for sure what I need to upgrade my '98 SRX 700 to the newer CDI with the built in detination sensor? Or know of an after market detination sensor ?
You'll need the magneto, flywheel, CDI, wiring harness, all other electronics (headlight, all relays, etc), water rail, and the DCS sensor off of a 2002 SRX. Sounds expensive to me.
Is there another CDI box that could be used on a srx 700 than does not retard ignition rapidly after 8600 RPM?? Does the srx 600 CDI have the same igntion map???
