Exciterfan
I need a little help with my 2001 SXR600. I seem to be fouling spark plugs every time I start the machine up after it's been sitting for a day or two.
It starts normally (not flooded), but soon drops from three to two cylinders. It's not always the same cylinder. Check the plugs and one or two will be wet.
Put a new plug (or two) in and away she goes. I took it for a good long ride on Saturday and thought all was well. Started it up Monday afternoon and it started to chug and run on two cylinders.
I did clean the carburators before the season started (although I'm not sure I cleaned the choke mechanism innerds???). Could it be the choke plungers getting stuck?? I did ensure that there is sufficient play in the choke cable.
Any ideas???
Exciterfan
Any ideas???
Exciterfan
