tommyt5078
I have been searching for any info on it and nothing comes up.
I've searched here and the tech area nothing.
Can someone lead me in the right direction?
Thanks,
-Tom
Thanks,
-Tom
yamaholic22
i loosen mine until it ratchets, and then tighten it in small increments until it stops ratcheting. Usually with a studded track i have about i would say an inch to an inch and a half of sag with no weight pulling on it where it hangs the lowest.
Tod
to add to what holic said............
Losen the rear axle, 17mm and 19mm. Then using a 14mm on an extention tighten the ajusters located at the back of the axle. You will go through the track window to get to these.
When you tighten the right side the track will move left. For tighness see Holics post above.
re-check for side to side after tightening the axle.
Tod
Tod
yamaholic22
lol, i'm a donkey. I didnt even think that he might be asking how to do it. lol
tommyt5078
Thanks guys, I was looking for the info as how to do it. Now I know
I'm really surprized that there isn't a write up about this some were on the site!
