SRX track adjustment
tommyt5078
New Berlin,Wisconsin
I have been searching for any info on it and nothing comes up.
I've searched here and the tech area nothing.
Can someone lead me in the right direction?
Thanks,
-Tom
i loosen mine until it ratchets, and then tighten it in small increments until it stops ratcheting. Usually with a studded track i have about i would say an inch to an inch and a half of sag with no weight pulling on it where it hangs the lowest.
to add to what holic said............
Losen the rear axle, 17mm and 19mm. Then using a 14mm on an extention tighten the ajusters located at the back of the axle. You will go through the track window to get to these.
When you tighten the right side the track will move left. For tighness see Holics post above.
re-check for side to side after tightening the axle.
Tod
