99yamahasrx
just started the sled up....seems that there is a little vibration until you rev it up to about 2500 rpm.....what could be causing this...thanks
If this is the first time that it has been started this year, I would say that the carbs(pilot jets) need to be cleaned. It most likely isn't running on all 3 until you get off of the pilot jets.
99yamahasrx
no i have about 300 miles on it this year
adam4by4
Crank Been Redone??? Or Noticed Any Problems At Higher Rpm I Think Vibration Is A Symptom Of A Bad Crank
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
Maybe something in your steering came loose so it just seems like the sled is vibrating bad?
99yamahasrx
no its not bad at all....completely leaves at 2500
bluewho
it could be you primary clutch check it for broken parts.
99yamahasrx
primary is brand new.....also the sled runs awesome in the higher rpms....if it was the crank it probably wouldnt run this welll would it???
adam4by4
Doubt It. It Would Probly Screw Somethin Up If It Was The Crank
bluewho
is the clutch tight can you see it wabble when it is idling or put a gage on it to see if it runs true.when the 98 cranks were bad they would run fine but you could see the clutch wabble when at a idle.sounds like it happens before engagment.
