Help with heated grips
nysrx
New York
I have an 01 srx and the hand warmers just stopped working. Anybody no where to look for problem. Thanks
Check all the wires coming from the voltage regulator through the grips. It's located just above the right footwell. It is aluminum with heat fins and had blue plastic on it. My guess is you have a wire that has had the insulation rubbed through. I had the same issue but I only lost one grip. Found the short, taped it up and they worked fine. You may also just have a loose connection, check all the connectors too.
Greg
Click on the page below. This has a lot of good info. Either one of your grips is bad( broken wire inside) and not making a circut or one of the wires connectors have jiggled loose, is usually the problem. Also you can type in "hand warmers" in the search button and you will find alot of info there. Mine quit last year, and it was a bad hand grip. Soc
www.totallyamaha.net/forums/showthread.php?t=8045&highlight=hand+warmerscomplete
