gas sprays back though carb. ASAP
Dfunkdf
Union City Indiana
I have a 01 700 sxr and it has a low end bog i ran it without air box ( i didn't ride it though) and it sprays gas back out of the carb until the rpms get up and then it stops any help thanks
do these 2 things first
Have you REMOVED the reed block from the engine and held it up and looked to see if you can see light around the edges?
have you put a compression guage on all 3 cylinders?
the reason I ask is sometimes if you simply stick a ring in 1 cylinder, it will have excessive leak down and cause the exact problem you describe. will run fine at mid and high rpm, but low end is boggy.
yes i have there is no light between the reeds and the reed block
