Just picked up 01 srx need some ideas!
JENSEN
Barrie, Ontario, Canada
I just picked up my 01 Srx and was wondering what kinda cheap, no brainer mod's i could do, jetting , clutching or anything else reasonably cheap :yrules:
depending on the miles your clutches will wear first changing both springs and bushings and installing new pins with washers for the wieghts and dont forget the secondary plastic ramp pins.it might just go faster as well i see you are from barrie welcome aboard.len
this is the biggest weekend but the track is kept pretty good all year.slows down after the trails are opened.raidar runs every weekend bottom end of simcoe and drag track is down the canal keep to the left first t and you are there.little early for running big ice yet but the track is flooded 2 lanes wide.i would leave the air box alone and jetting as well if the plugs look good.cya
