Fasterblaster
Im not a heavy person (160 lbs) and I find this machine a lot harder to control than my Phazer. Is this just the weight and characteristics of this machine with a 1.5 inch 136 track or can I make some adjustments to give it better manners?
Post all of your suspension settings, and any suspension, ski, or track mods.
Fasterblaster
Sorry for the delay Ding and thanks alot for responding.
Pardon me if I am not using the technical references here...
Rear Suspension: back shock spring set at 5th from highest setting
front mount of that same shock on the lower notch
front shock at highest setting
limit strap screw/bolts set almost full open
track is 1.5" 136 off a Ski-doo (are these directional?)
Front suspension - shock springs at second lowest
Stock plastic ski with 6" carbide
I'm about 165 lbs - above average aggressive riding
Faster
Faster
