Can't find my fuse housing under hood
YAMAHIZAL700
durham, ME
Hey guys, I was wandering if someone could tell me where the fuses are located. I was told they are on the right side near the pull cord in black box but they seem to be doing a good job of hiding from me.
Yes there is, it is on the right side by the pull cord. You have to remove the top to see the fuses. There should be a group of wires going to it. What sled is it on? Where are you at? Maxdlx
Hi maxdlx, thanks for replying. I ended up fixing my problem last night. First of all I could not find the fuses for the life of me and oh yeah its a 99 srx 700. I took off the black vented cowling that the pull rope goes through and still traced wires but found nothing. What i did find was the wire plug right by your foot slot that feeds under the gas tank and to the seat. I unplugged it there for the hell of it and to my amazement there was power to the tail light! So next to make sure I wasnt losing it I rechecked the plug at the tailight housing still for some reason I had brake light when I pulled brake lever but still no tail light. Then I figured Tj500 was right and must be some sort of rub through under the seat. Once I got the seat off the wires looked nice and neatly tucked away so I plugged her back in and magically i had a tailight again so what Im thinking is the connection from gas tank to seat had wiggled a little loose because all the time I had no tail light I still had brake light. Just to be safe I taped the two pluggs tighly together so it cant seperate itself. I still would like to find the damn fuse housing but all the searches i do and everything else and still I cant find much on fuses at all! Anyway I wante d to say thanks for all of your help. Jason Holbrook
