snoseeker VIP Member Joined Aug 6, 2005 Messages 29 Age 62 Location minnesota Dec 26, 2005 #1 Spark Is Weak Then Change Plugs It Ok For A Bit Then One Hole Will Lose Spark Change Plugs It Ok Help Please Last edited: Dec 26, 2005
Y yamaddiction New member Joined Nov 14, 2004 Messages 41 Location maine Dec 26, 2005 #2 i just had the same problem yesterday with mine, it was one if the spark plug caps was rusted where it screws into the plug wire, try a new cap or one from another cylinder
B BLUEBY New member Joined Feb 11, 2004 Messages 175 Age 50 Location minneapolis Dec 26, 2005 #3 Ran into the same problem!!! with my brother inlaw's 98 SRX and it ended up being the cdi box. So maybe start by checking it and the stator?
600srxman New member Joined Nov 27, 2005 Messages 217 Age 38 Location Sarnia,ontario,canada Dec 27, 2005 #4 or the pulse coil
ejcamaro Life Member Joined Sep 24, 2004 Messages 910 Age 47 Location Wonewoc, Wisconsin Website www.myspace.com Dec 27, 2005 #5 Mine was the wiring harness under the motor. Would weaken the spark enough to foul a plug when you hit the perfect little bump.
snoseeker VIP Member Joined Aug 6, 2005 Messages 29 Age 62 Location minnesota Dec 29, 2005 #6 thanks for the help guys
