Rambunctious
what's proper method to clean a clutch (housing, components, and sheeves) and what is the torque spec for the bolt
use blue locktite too?
thanks
Ramb
thanks
Ramb
YAMAHIZAL700
I used a soft brillo pad and warm water. It works better than gas or any other nasty chemical I could find. Really eats the black marks off of everything.
I disasemble the clutches and scrub in parts cleaner, blow dry and also use contact or brake cleaner to get them dry and then assemble dry - do not lube anything.
Torque spec is -secondary gets 4.6 foot pounds.
primary gets 87 foot pounds - break it loose then 43 foot pounds
This is from a 700 manual.
Tod
Tod
Rambunctious
thanks
