main jets 700 sx (97)
jmp2204
eastern ont.canada
i did the reed notch and while apart pulled the bowls ,it's got 141.3 accross the board thats 2 sizes down from std,whats everybody runnin for mj's ? do i need to rejet for the reed notches?
sea level or around sealevel same as watertown ny but i don't know exactly.always usually jet at standard setting unless the sled is running rich or i know i won't be doing extended runs at w.o.t.,i've been out of the the game for a while and i'm not up to snuff on this sled (updates ) thanks for your help
141.3 sounds lean to me. On A stock machine 142.5 accross the board is about as low as you should Go safely.It will also be fine with reed notch.
How are your plugs and piston wash? My 600 was jetted down about 2 sizes for somewhere around sea level. Stock is: PTO: 136.8, Ctr/Mag: 133.8. I was running 133.8, and 131.3's. Just check your plugs and if they look good you should be o.k. I may go a little bigger on the PTO side if it were me though.
