jvizzacc
Anyone ever heard of this one?
01 SRX700 bone stock 2400miles
Ever since I got this sled at 800 miles there has been an idle problem. Once it gets warm, it wants to idle around 3-5K or just before the clutch starts to engage. Nothing I can do slows it down. It's not much more than a nuisance, but I'd still like to fix it. It does this about 90% of the time once it's warm.
The throttle cable appears slack enough at idle.
Thanks all.
Thanks all.
sounds like you got a vacume leak. have you checked your carb boots with propane/starting fliud/oxygen (i recommend this one) afer it has been warmed up? how do plugs look? should have a lean looking plug if any of these are the problem. check the crank seals too while you at it.
jvizzacc
All of the plugs are the same color. Carbs have been R/R. Everything looks right, it just won't idle dammit!
Am I the only one who has ever had this problem?
