MrChetStuart
Hey all,
I was in the process of changing slides on the GF's 98 SRX700 this afternoon when I discovered some track damage (see link below). I'm relatively new to doing my own maintenance & thought I would ask for some opinions on it... I was hoping to not have to stick much money (beyond the basics) into the sleds this season (read: I don't want to have to buy a new track), but if this one is totally shot I will have to replace it I guess. It is the stock Yokahama that came with the sled - sled has about 2700 miles on it. Should I replace it or could I safely get by with it this season? Thanks!
Pic of track damage
Pic of track damage
yamyrider
I would replace it.
You are gonna be out on a nice ride and it will let you down.
Or you will be flying across a lake or long straight away and when she lets go look out.
bluehammer
It's the beginning of the end. Like he says above. Why have it fail where you don't want it to?
YAMAHIZAL700
Change it! Change it! Think about how it will stop without a track on it. Not very good!
maxdlx
VIP Lifetime Member
I have the stock track out of my Viper w/140 studs in it. I'd sell it for 100 bucks plus shipping if you want a track to get you by. Maxdlx
srx dreamer
2700 miles on a yokohama track!!!!!! Uve done well I would not want that thing on the back of my mind while riding it. U got ur money worth out of it and have done better then most. Id change it.
SRXSex
That is a conveyor belt now.
MrChetStuart
Well, I guess I don't need to sort through any differing opinions on this one! Time for a new track. Thanks for taking the time to reply - much appreciated.
jwifferdill
Life Member
The stock Yoko tracks are absolute junk, especially the 98s. My 99 had a bit better one, but not much. I went to a 1" Camoplast and although I've had a couple studs tear out because of overtightening, I haven't had any lugs rip or any other damage. Put a Camoplast track on, you won't be sorry!
MrChetStuart
jwifferdill said:The stock Yoko tracks are absolute junk, especially the 98s. My 99 had a bit better one, but not much. I went to a 1" Camoplast and although I've had a couple studs tear out because of overtightening, I haven't had any lugs rip or any other damage. Put a Camoplast track on, you won't be sorry!
I had looked into tracks a few months back & deceided that if/when I needed to get one for either of my SRX700s that I was going to try the 9830. I have read the stocker was crap, so I am pretty anxious now to get a different track on there to see just how big of a difference there is going to be. If it works out, the other sled (the one I use) is getting a new track too!
SRX M10
Put your track on her sled and buy a new one for yours, am I the only selfish male here or what?
jwifferdill said:The stock Yoko tracks are absolute junk.
The yoko's are ok if ya don't spin them...but who can do that...
bluewho
Saw a guy try to get the rest of the winter out of a track like that he got the rail stuck in the broken window and bent the end to boot.He was comeing out of a little swamp and got it stuck at the bump comeing out.Earned himself the name SLEPLUCK.
tntmax
Go 1"1/4 ripsaw and you will have a hard time holding on to your bars...
srx dreamer
go 1 in if u want some studs.
turned the yoko off my '98 into a great stud mat!!!!!!!!!!!
MrChetStuart
SRX M10 said:Put your track on her sled and buy a new one for yours, am I the only selfish male here or what?
I most definitely thought of that already lol... but like I said, I am pretty new to doing my own repairs and would like to just get hers taken apart and reassembled sucessfully to gain that experience (plus if I mess something up while I am working on it, I still have mine to ride!). If all goes well getting it swapped and the track kicks ***, I will swap mine out for a new one too then.
viperino
maxdl, i sent u a pm about ur track
nhsrx701
- Jan 27, 2005
do yourself a favor and take a razor blade and cut the old track right off the sled...then pull out the suspension...no sense is fighting to pull the supension out of a bad track....just saves time...rock on!
just an fyi cause you said you new to this! plus make sure you use lock tight on the bolt that hold the gears on the cog shaft when you put it back together. bought a sled that had a track change and the bolt backed out
