BlueRider17
How do you guys remove the bearing for the top shaft that is in the outer side of the chaincase?
insaneSXR
i couldent figure that one out either. took it to the dealer and it took the mechanic about 5 min. charged me $5. to bad he did it in the back i would have liked to see the rig he used
ModMMax
Its a bearing puller that has a slide hammer on it. The trick in this case is to heat the aluminum with a heat gun before you try to pull it. Comes out easy.
