Sled starts and idles perfect .....Low power and only revs to around 5500 rpm Carbs are good .... 125 psi both sides ....exhaust not obstructed ...New CDI ..Any ideas ?????
T.S.U.Filmz
check air box
KING OF THE LAKE
Check The Pipe For Being Plugged. Animals Build Nests In Exhaust Which Chokes Off Power Output. If Nessary Remove And Run Temporalily Or Replace With Known Unplugged Good Pipe And Try.
Blue Devil
Are the plugs inside the carbs in the right place?? If the are in the wrong holes this my be the problem
profyamaha
Check your TORS, Throttle override switch. Bypass the switches by unplugging the two wires at the carbs and plug them into each other.
airbox off...pipe off...tors bypassed .....carbs good to go....same results .....does the stator have both high and low speed windings ???
PZ 1
- Mar 12, 2005
Are you sure these are right?Blue Devil said:Are the plugs inside the carbs in the right place?? If the are in the wrong holes this my be the problem
What is the history - what happened before this?
