95 600 vmax dx track drive housing to track drive?
hereismylife
Pa
Website
www.hereismylife.com
hello,
95 600 vmax dx
I am tring to take off my reverse and drive housing out of my sled. I got the 4 main bolts off from the frame and got it loose. It moves about 1/2 inch and stops.
here's the questions I have?
Is there a bolt that goes from the drive housing to the track drive(cog drive)?
what would you replace while having this off?(I am replacing left and right gear drive bearings)
If i have to split the drive case what lind of oil do i use?
thanks for your time and any info you can help me with
joe
i dont know abought a bolt or nut some times it just needs a little pull as for the oil use 80/90 or snowmobile chain case oil i use the 80/90 my self
you sure do have to take cover off chain casing and remove gears, only way to replace bearings!
j_k_auto said:
hello,
95 600 vmax dx
joe
I'm looking for the alternate reverse gear shaft if you are taking yours off and want to sell it - let me know - thanks
