I had the best mechanic in the county to install the tempaflow, but he still made errors, since he had not installed one of these before. He cut the tube that connects the outlet tube to the tempaflow with a fitting too short, the outlet tube itself too short, and he sat the needles on 2,5 instead of 3,5. It is 2,5 according to my yamaha book, which states that clip in middle position with one shim over and one under is 2,5. He should have sat it on the second uppermost with one shim over and one under.
Anyway, I was able to fix the short tube that attachs to the tempaflow, sat a longer one in there. But, I have no Idea how long the outlet tube from the tempaflow to the carb is supposed to be. Instructions state from 16 to 24 inches. This is a recently bought tempaflow, and when looking at srxdudes tempaflow install on his 99 srx I see that the tube is 30 inches long?
I read somewhere here that the length of the tube affects the tempaflow, so I need to know how long it is supposed to be?
