braindead1684
I was wondering what size gas tank my 96 vmax xt has. Also this sled has a 121x15 track right, One place i saw said it was a 136 or something like that,
mikematthys
should be the same size as mine witch is 49 liters or 10 gal give or take also your track is a 121 x 15 the 136 would be a long track but that is an extra. i had a 1994 vmax and the specs as stated above
profyamaha
I had a 1996 vmax xt, bought it new. Great running sled, tons of fun, handled great, but it really sucked the gas! I had Hacker's re-tune it several times but it never improved. It think the tank was 11 gallon. Mine got about 8 mpg.
braindead1684
Ya my xt gets about 6-11 depending on what kinda riding i'm doing. We where up north last year and i took 3 gallons to my dads 94s 8
but i agree those sleds like to drink. Thanks for the info i was thinking that track was the 121. Thanks again.
but i agree those sleds like to drink. Thanks for the info i was thinking that track was the 121. Thanks again.vmaxjohn
Back then I think the long track designation was an ST. You should have a 121"er I believe.
Yes i belive 10 gals.
I don't know why you guys have a problem but all our older vm's get
10-12mpg depending on conditions.. and i;m not sh*ting ya ether
but ther also dialed in perfect too and all stock.
caravanman
10 gallons and 121".
The XT was not available factory with the 136"
I get 10 to 13 MPH. Thinner head gasket and minor jet change helped to wake it up BIG time. Factory clutching was poor too.
braindead1684
I have another question now, what are the dimensions i need to align the clutches properly. The reason I ask is that I have a slight belt squeel that only occurs after the sled has moved and then stopped again and with the rs around 3-4k. we rebuilt the primary (burned out roller along w/ bushings) The secondary which is off right now is getting new ramp shoes and new bushings. I am hoping that is was not backshifting all the way which was the cause of the squeel after the clutches engaged the first time.
On a side note the sled has twin gyt pipes on it so i am happy with the gas milage not to mention the majority of the miles i have put on it have been with the burned out clutches so hopefully it goes back up.
Could be the belt is too tight,may have to remove a shim from the secondary clutch bolts
braindead1684
By between clutch bolt do you mean between the bolt on the jackshaft and the outside of the clutch, as i put one more in there which made the squeel a little lighter it had some slop in there before and was squeeling with that gap in there.
there's 3 sims in the back of the sencondarys bolts you can take out, witch
will spred your clutch apart thus loosening the belt a little.
ski
I found a great way to save fuel ... slow down a bit.... LOL big difference on my 97 500XT, dropping from 65mph cruise speed to 50-55
