need help removing drivers
  • Thread starter Thread starter srx_eh
  • Start date Start date
S
srx_eh
Guest
I have my VMax dangling from the rafters of my garage the skid and track pulled out and an axle and drivers sitting on the workbench.
How do I pull the drivers from the axle, without damaging them?
Thanks for the reply,
I would assume this is pretty routine through a dealer.
yeap
Dealer can do it, but its cheaper to do it your self. What are you doing going from say 9 to 8 tooth. if so, just mark the axel with a good permanate marker, let it dry good, press the old ones off, then press the new ones on. Be safe to make some measurements too. maxdlx
max,
Yes, I'm going from 9T to 8T as part of a track change, ...you mentioned "pressing" the drivers on and off, what do you use as a press?
well
I Just use the big hydraulic press at the shop. I know not everyone has that convienence, but you probably know someone who has one. Maxdlx
