S
srx_eh
Guest
I have my VMax dangling from the rafters of my garage the skid and track pulled out and an axle and drivers sitting on the workbench.
How do I pull the drivers from the axle, without damaging them?
they will need to be pushed off with a hydraulic or arbor press
S
srx_eh
Guest
Thanks for the reply,
I would assume this is pretty routine through a dealer.
Yes, Most of the dealer I deal with have them amd the specs..
yeap
Dealer can do it, but its cheaper to do it your self. What are you doing going from say 9 to 8 tooth. if so, just mark the axel with a good permanate marker, let it dry good, press the old ones off, then press the new ones on. Be safe to make some measurements too. maxdlx
S
srx_eh
Guest
max,
Yes, I'm going from 9T to 8T as part of a track change, ...you mentioned "pressing" the drivers on and off, what do you use as a press?
well
I Just use the big hydraulic press at the shop. I know not everyone has that convienence, but you probably know someone who has one. Maxdlx
