jetting phazer with v max carbs
yamajer
harris,mn
I have a 91 phazer and I am going to put v max flat slide carbs on it.Can anyone help me on were to start on jetting :yrules: :yam:
check to see if the 96 or 97 phazers had flat slide carbs and then use those jetting instructions....other than that ???? I wouldn't change the carbs them unless your doing something else to the motor....
On my 91 I ran either 155 or 156.8's. Needles in the middle with both washers under the clip. This was at 1000' and temps from -10 up. No airbox on it ran filters, piped, ported, thin head gasket. I'm sure I could have leaned it out a bit more, but it worked well and stayed together like that for 2 years.
