O.K. I "m running with the 53/43 helix grn spring at 60,inch and quarter ripsaw,I dropped to a 21 tooth gear, and totally rebuilt my primary this year- running 8dn20 with 4.5 in both inner and outer. From a dead stop its great pulls hard to 8400rpms,top end is good too from 100km up its fine. Heres the problem running in the 40-100km zone its a dog really slugish until I reach higher speeds then its fine ran 8400-8600 rpm all day!! Do I need to change my primary spring from a stock one to stiffer or less stiff?? Or does the secondary need to be wrapped higher or does that spring have to be changed!! I know the weights are heavy but the Rpms are perfect!! Help me out boys!! The motor and exaugst are stock!!
