sled at 9500 RPMS??
Roushrider81
i have aaen pipes on and last night i noticed my belt was shredded badly... changed the belt and no it reving up to 9500 when i pin it. is that over revving my sled (2000 yamaha v-max 700)
Running aeens on a 98 vmax700. Our clutches and springs are the same except your year has a 10.3 inner weight and mine a 13.9. All I did was add a engagement shim and wrap the secondary to 70. 9200 with a new belt down to 8800 on a old belt. Hope this helps.
yamyrider said:
what weight are you runing, helix.
I have aaen and I got a great set up.
well everything i have right now is stock on the clutch excemp for three spacers in the stock spring.... i do have an after roller for the secondary...but it is not in yet. what are you running for your set up??
If you neglected to thoroughly clean the clutches, I'd start there. Also, new belts have a release agent on them, and hitting them with full throttle off the bat will usually glaze them and the clutch sheaves, causing over rev.
I'd try an older belt, scotch bright the sheaves, and clean the heck out of the clutches. Then consider adjustment if it's still higher than you're target rpm. Good luck!
