whoa,whoa whoa, you cant just drill it out for 1!!!!!, it wont close off the port if you do that, its offset. So you have to know what the correct offset is before you open the hole. It by itself isnt 6hp, but along with other mods to the cylinder boost hole it is worth a gain in hp, it helps to cool the underside of the piston crown more, and helps lube the wrist pin/bearing better, providing more mixture in the case on the downstroke.
