jwifferdill
Life Member
Just installed a new primary spring today after running the previous one for two seasons. When I first got on the sled, I noticed the engagement was slightly higher than with the old spring. They are the EXACT same brand and color springs. Does this say something for the old one, like perhaps it was shot and needed to be replaced? I also added more weight to the mid hole on my Heavy Hitters while I had the clutch apart. If anything, I would have thought the engagement would have dropped.
ovalracer
The sprung height of the spring was probably a little taller with the new spring, with a taller height it will engage higher, kinda like adding engagment shims.
jwifferdill
Life Member
Makes sense...I'll throw a bit more weight in the heel of the Heavy Hitters and see where it sits then.
That is normal, With your new spring your engagement will be higher (than a worn spring) and you total shift more than likely will be higher as well.jwifferdill said:Just installed a new primary spring today after running the previous one for two seasons. When I first got on the sled, I noticed the engagement was slightly higher than with the old spring. They are the EXACT same brand and color springs. Does this say something for the old one, like perhaps it was shot and needed to be replaced? I also added more weight to the mid hole on my Heavy Hitters while I had the clutch apart. If anything, I would have thought the engagement would have dropped.
jwifferdill
Life Member
Great, thanks for the help guys
mtnmx
- Jan 4, 2004
Just a hint change only 1 thing at a time.......
jwifferdill
Life Member
The old primary spring must have been sacked out because with the new one in there it runs noticably better. More top end is the main thing I noticed.
jwifferdill, what gearing do you have on your sled, and lug height? whats your top end?
thanks
thanks
jwifferdill
Life Member
23/37 gearing, 1 inch full block Camoplast track. Top end last night across the lake with about 5 inches of snow, kind of packed down...105mph and climbing a bit. That is a speedo reading, however. On hardpacked trails and roads it buries the speedometer.
