If you have replaced your ignition coils I would be interested in the problems you were having that made you replace them.
I know there is a spec on them as far as measuring the resistance at a certain temp.
I will foul a plug every once in a while for no good reason. Oil pump is adjusted to be lean, carbs are clean, sled runs great but then it will just foul a plug out of the blue.
FYI - My sled is a 97 700SX with pipes. Same jetting the last 4000 miles, no problems with plug fouling before
