Viper shocks in an SRX
good thinking Yamahizal, I just barely bought a set and didn't think I could put them on, untill seeing this.
I have a question about the rear. I can't seem to mount the long shock?? I can't flip the center shaft after bolting it in.
Did you install the new viper limiter straps? If not, you need to and then you can loosen them all the way up. At this point the rear shock should bolt right in but make sure it goes in the way the other came out. Then you can tighten those straps right up. If it isnt easy your doing something wrong. They fell right in for me. Hope this helps.
