phazer95
gpxsrxracer said:They dont look the same, they may perform the same.
Well here is the exact quote from DYNOTECH vol.4 #1 page 5
"The pipes we tested included the PSI single power pipe,PSI twins,DG single pipe(which looks EXACTLY like a PSI Single),Decker can pipe,Dynoport Single pipe,Aaen Quiet can pipe and the Aaen straight single silencer pipe"
These pipes where tested on a race modified phazer with flatslide carbs,porting and special Bender SX piston cut and very tight squish clearance of .050 that requires at least 100 octane fuel for anything longer than 1/8 mile runs.
Here are the peak power numbers
PSI Single-82.3@7500
PSI Twins-79.4@7750
DG single-83.2@7750-8000
Decker can-79.2@7250
Dynoport pipe-83.0@7500
Aaen quiet can-83.4@7500
Aaen single-82.5@7250
As you can see the DG has the broadest power peak on a modified motor.
The PSI Twins should only be used on a modified motor with flatslides but even then do not deliver the best power.
