I have a bog from idle but runs fine after i get going. I think it the TORS system. HOw can i by pass TORS on my 2002 viper?
CAn someone help me out with location of the plugs to tie together?
y_guy said:I have a bog from idle but runs fine after i get going. I think it the TORS system.
it's not the tors then if thats what it's doing,
check your carbs out.
But it runs just fine once it gets going. Its only when sitting at idle then taking off it bogs. But once you get it moving it doesn't do it anywhere in accelaration.
There has been plenty of discussion about the location of the TORs wires, what your descibing doesn't sound like them...but in the middle of the carb rack under the throttle cable is a sensor with two wires. Pick it there and follow it to the end. Unplug the two wires from the harness and plug the machine side wires into each other.
When tors kicks in it wont run right at all, from just above idle to WOT
tors is kinda like a rev limmiter on a car
you got something else going on there,have your carbs been cleaned and adj. latley
yamvip
yeah its not the tors....
Any idea other then carbs ? i cleaned them last year and i DIDN"T use sta-bil but rather Sea foam over the summer. Not only that, but it ran okay for the first 50 miles and it's getting worse every day.
You need to clean the carbs every year. Doesn't matter what is in them, the gas will tarnish. Maxdlx
