sniperviper
Have heard that the viper with tripple pipes is not as strong as the srx, any truth in this?
Man put some helix to that viper at LEAST a 53/47 with a short track...I run a 56/46 with my 159x 16" and a roller sec. and you will kill that srx..had both sleds.02 dump the green and run the silver sec spring with this.......03cwcsrx700 said:We put slp's on a 03 viper w/recommended jetting and clutching parts it runs really good. With comparable tracks and studs are almost wore out on both machines, the viper jumps out in front at first, aftermarket rods help here though. But about at 70 the old trusty 02 srx will reel it in and the viper is always behind it at 100, the faster you go the bigger the beating the vipe will get. There is a can on the srx, WWW pri. 48/40, geen sec. the clutch work didn't seem to help it much though.
