acnas
What are you guys running for studs and what lenght? I have a 02 Viper with the stock track. Currently running 96 Woody's gold diggers and 48 Woody's Chisel Tooth. I have studs on outside and in the middle. Chisels are in the middle every other row. Looking to replace studs as they are worn. Was looking for maybe a different brand to replace these. I ride in NH where we get the ice to packed snow. I have the chisels for the occasional Ice drag. Also I am running 1.075 lenght of all studs. Has anyone gone longer with this track without any problems? Was looking into the Stud Boy power points 1.080?? Any info would be great.
acnas
ttt
richierich
the longest you would want in a woody is a 1.175".roetin would be 1.08".studboy 1.08".
i have some roetin hornets for $1.25 each stud and nut.studboys would be $1.60.let me know if you need anything.
acnas
Woody 1.175 how much would it be over the lug. More than what I have now. Will it be close to the front exchanger? Hook up would be great?
richierich
on your stock .92 track it would be 1/2" above alittle on the long side.but if you switch to a 1" lug track you will have 3/8" if you plan on upgrading you can reuse them.if you keep your track tight you'll be safe.
