Studs
acnas
Epping, New Hampshire
What are you guys running for studs and what lenght? I have a 02 Viper with the stock track. Currently running 96 Woody's gold diggers and 48 Woody's Chisel Tooth. I have studs on outside and in the middle. Chisels are in the middle every other row. Looking to replace studs as they are worn. Was looking for maybe a different brand to replace these. I ride in NH where we get the ice to packed snow. I have the chisels for the occasional Ice drag. Also I am running 1.075 lenght of all studs. Has anyone gone longer with this track without any problems? Was looking into the Stud Boy power points 1.080?? Any info would be great. ;)!
the longest you would want in a woody is a 1.175".roetin would be 1.08".studboy 1.08".
i have some roetin hornets for $1.25 each stud and nut.studboys would be $1.60.let me know if you need anything.
Woody 1.175 how much would it be over the lug. More than what I have now. Will it be close to the front exchanger? Hook up would be great?
on your stock .92 track it would be 1/2" above alittle on the long side.but if you switch to a 1" lug track you will have 3/8" if you plan on upgrading you can reuse them.if you keep your track tight you'll be safe.
