snowprophet1
I got 1 1/2 months of riding on my 780 bb setup (a little over 3,000miles). Great gas milage, and power was raised. The last day of my trip up north, it sounded clattery, idled like crap, and started hard when warm. When we got back, sure enough compression went from 127ish psi down to 110, 70, and 80. I tore it down last night. The piston coatings are like brand new still. Temps on gauges were always running the plugs a beatiful safe brown. Water temp ran usually 160*F, but saw 180*F for about 5 minutes of riding. (regular temp light never came on). The cylinders are still in good shape, but the skirts of the pistons shrunk .005"! The second rings down were all stuck, the top rings were all slopping up and down around the exhaust area, (with one ring even being cracked!), and the slop was because the top of the piston near the main exh were actually starting to get raised! No melting. No seizing. Piston skirts were in nice shape, but like I said, they shrunk. I ran a piston to cylinder clearance of .004", and had the piston tops ceramic coated and the skirts w/the friction coating. Is this an every year thing with the big bore kits, or do most people get years out of the same rings? Any stories on longevity? I just want to know what to expect next year.
