Helix?
norwegian
Well-known member
norway
My sled has this set up:
white blue white primary spring, 8bu weights, secondary with green spring and a 51/43 helix and 22/40 gearing. I have a straight 43 helix laying around here. Can I use this for deepsnow riding or will I mess anything up with the clutches, break anything? The reason I want to use this helix is that it does not gear up as fast as the 51/43..
The stock weights work fine with the 51/43 helix & will backshift very well.
I haven't god the stock weights at hand. I believe the stock are 8dn weights? Mine has 8bus...
