WATCHMAKER
I am finally finishing a project that I started about 10-12 years ago. It is a 1990 Exciter with all kinds of mods and new parts. I'm going to focus this post on the engine mods because I need help with the clutching. Maybe some of you guys will have some old notes.
--stock bore and pistons
--PSI single pipe
--PSI lake/race porting
--PSI head mod (about 130-135 cranking psi)
--cold air kit
--carbs off center bored to 39.5
--pipe, y-pipe, pistons and combustion chambers ceramic coated
--crank trued, balanced and welded by Falacon (FL) They took a lot of material off. (pork choped it) Hope that was not a mistake with the vibration problems Exciters were known for. I did not know they would remove so much metal. I did add a PSI harmonic balancer.
Now for the clutching.... I modified the secondary for a wide belt (cut helix where snap ring goes) and the primary is a Comet 108 EXP. Does anybody have a clutch set up that would work for me? I have searched the archives and found some setups for stock Exciters but not for a ported/piped one.
--PSI single pipe
--cold air kit
